ecu fuse keeps blowing
well i have an 94 civic dx ls v swap p28 ecu
my ecu fuse keeps blowing like when my fuel pump primes the ecu fuses blows
i think it my main relay because it was making some weird noises and now the fuel pump doesn't prime can someone help me out???? what do u think is wrong ????
i would appreciate the help thanks!
Re: ecu fuse keeps blowing (brasiliangee90)
You could try a new main relay, check the wires from the alt. though behind your motor, i've read a recall on it where they short out on the bracket that supports them. I dont know if this will cause the ecu fuse to blow though.
Re: ecu fuse keeps blowing (z6hatchboy)
yea imma check on that thanks and i got a new main relay so ill c if that fixes the problem. thanks!
