sohc tranny making noise[ bone stock dd]
anyone heard a sohc tranny make a loud rolling noise only when the clutch is NOT engaged..?? is a tob? https://honda-tech.com/zero...&id=1#
Re: sohc tranny making noise[ bone stock dd] (MK1 deR)
when you say not engaged, do you mean the pedal is pressed? this could be the throw out or the pilot bushing. what kind of noise, a squeal is the pilot.
no its not the release bearing. I had the same problem. I replaced the bearing, put everything back together and still had that annoying sound. Its something I believe in the gear box, I just ended up buying a new tranny. Problem fixed!!!
Re: (809JDM)
Its the bearing on the other side. I cant remember what its called off the top of my head.
I did what the guy above did, get a used tranny coz mine whined pretty loud with the clutch pedal not pressed.
I still have the whining trans that grinds third gear as a spare once i can get it rebuilt
Emshhh
11
02-02-2005 11:10 PM
NickW
10
07-25-2004 01:25 AM
