Code #6 ect need HELP!!!
Old Apr 25, 2008 | 05:04 PM
jdm_eg's Avatar
Default Code #6 ect need HELP!!!
as the topic says i have a b16 an cel came on, i put a paper clip in the plug n it flashed 6 times, ETC code. I installed a new coolant temp sensor the two prong one n light still on. the other sensor(one nipple) is for the gauge cluster i might be wrong and the other 2 prong for the ecu. the coolant temp is reading on the gauge cluster what else could it be.
Old Apr 25, 2008 | 07:46 PM
slowcivic2k's Avatar
Default Re: Code #6 ect need HELP!!! (jdm_eg)
Signal wire from the sensor to the ECM. Disconnect the ECM and check the wire/sensor in question for continuity. More than likely a contaminated connector. Oil likes to get in there and soften the plastic, and the pins back out.
Old Apr 25, 2008 | 07:55 PM
Former User's Avatar
Clear the code from the ECU and, when or if the CEL turns ON again, retrieve code and see whether code is still 6.
Old May 20, 2008 | 06:29 AM
munger's Avatar
Wondering if you still have the army green del sol for sale, very interested and a local pennsylvanian, thanx.
rudyndrew
Dec 30, 2010 02:12 PM
v8 integra
16
Feb 27, 2007 08:10 PM
mprelude
Jan 10, 2005 11:52 AM
gsr2envy
Nov 7, 2004 03:32 PM
delsol93
Jun 21, 2001 02:54 PM
