93 dx cel will only come on while driving
Ok i tried to check the cel but it would not flash a trouble code nor come on when started it will only come on after driving a few mins them go right back to being off the next time i start it any ideas would be appreciated thanks
Re: 93 dx cel will only come on while driving (jimmy o.)
Did you jumper wire the service connector?
https://honda-tech.com/zerothread/1901557
The trouble code should be stored in the ECU even if the CEL does not remain ON constantly.
Re: (z6hatchboy)
I didn't work I really don't know if im using the right port also is it connected to something or is the service connector just a loose conector im new to this way checking it so i probably have no idea what im doing
Re: (RonJ@HT)
All it has listed is for is a hatch is the wiring the same as my coupe and it dosent look the same as what im trying to use
Re: (jimmy o.)
I rechecked it and it said he didn't know if it was the same color for all civics it just listed hatches anyone who knows how on a EJ1 let me know
Re: (jimmy o.)
Mine does this too 94 civic dx coupe with z6 swap, i cleaned up the fitv and now my cel comes on and goes into limp mode its not driving very good with the cel comming on, then when i turn off the car its good again for like 10 minutes of driving then cel and limp mode comes on again.....pls help
Re: (jimmy o.)
I goes by year i think for the color of the connector/wire. Go to the thread on the main forum list and see what color it is for the eg connector/wire and thats the one you use. Also if you didnt get it the first time, its in a green holder with a few others.
Re: (z6hatchboy)
i have a 94 dx coupe with a D16Z6 swap in it and i checked at the passenger side kick panel and removed the carpet but above the ecu theres no jumper plug? how do i check my cel now?
Re: (RDAYA0)
Just stick you hand in the lower passenger panel. The connectors are pinned against the panel if it has never been used. Pull it out, take the green cover off and your gonna see two connectors. One has 3 pins, the other 2. Take the one with the two. Grab a paper clip, if thats not availiable to you, grab a 3 inch wire, rip the ends off and stick it in the pins. once you do that start checking for codes.
Like you said the light will come on when driving so drive it and when the light starts flashing, start counting. Thiers no need to remove the carpet to get to those specific connectors.
slowesteg
05-11-2012 11:07 PM
ntrider
15
05-29-2005 01:53 AM
