NEED MORE POWER ON MY LS
I have a 1993 Civic Hatchback... i swapped a 96 B18b1 motor in it....i have a full 2.25" catback straigh pipe(eliminated cat convertor and resonator) and short ram intake.... i want to know wat else i should do to it.....money doesnt matter just looking for opinions.....im tryna stay all motor keeping it non vtec....let me kno....
You have one of the strongest blocks out there, and you just said money isn't an issue...
You already know the answer, BOOST IT. I have a 92 CX hatch with a 96 B18B1 in it, thats the road I'm taking.
Re: (Dasfinc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dasfinc »</TD></TR><TR><TD CLASS="quote">You have one of the strongest blocks out there, and you just said money isn't an issue...
You already know the answer, BOOST IT.</TD></TR></TABLE>
x2. ls block+boost=orgasm. lol just go boost...with no vtec and no boost your not gonna make that much power. everyone on here will agree when i say...go boost!!! whatever you choose, good luck.
Re: (andoxviii)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by andoxviii »</TD></TR><TR><TD CLASS="quote">Get a better tranny. You don't need more power to feel the benefits of a shorter-geared transmission.
Look for any other b-series tranny that isn't from a b18b or b20.</TD></TR></TABLE>
werd,
get a b16 tranny, and it will pick up alot quicker.
werd,
I don't understand how so many people think a short geared tranny helps SO much with a B18 when it doesn't....
Short geared transmissions are intended for cars that peak and have most power at high RPMS, B18's have useable power from as low as 4000RPM up to redline, so when you are only using 6000-7000RPM when going WOT, you are shifting so often, that you will be loosing speed...
B18 transmissions are also ideal for boost.
Also, to the OP, your car must be loud as [freak], because I have 2.25 exhaust, a 'high flow' cat, and a resonator, and I could not hear myself think before I added a muffler, Let alone removing the resonator and cat O.O.
Infact I got a headache after driving on the freeway for more than 10 min at a time.
Re: (Dasfinc)
hahah yea i kno man itz [freak]in loud but itz all gud wit me.....ima get that high flow cat soon tho bcuz sumtimes it does get annoying
Re: NEED MORE POWER ON MY LS (Nino_eg6)
well.... nitrous,
build all motor....
supercharge it....
add a turbo....
i would boost it , my friend had a boosted ls with stock motor in a 93 cx hatch and it ran 12.2s all day.( and it was a ebay kit )
build all motor....
supercharge it....
add a turbo....
Re: NEED MORE POWER ON MY LS (nicks-eg6)
all motor:
vtec head
high comp pistons (either p30 or pr3 im not sure, Im a boost guy )
arp rod bolts
good set of headers
cams
p&p head
aftermarket valve springs and valve job
vtec trans cause ls trans sucks
boost:
depens on your hp goal, budget and what you wanna do with the car b/c the options are endless from here
vtec head
arp rod bolts
good set of headers
cams
p&p head
boost:
Boot FTW:
Here's my HMT setup:
14B DSM Turbo, B-series Manifold for the 14B with a spot for an external waste gate, 450CC injectors, Resistor box. *And I also have a IC*
joshd_bh
10-09-2012 07:46 PM
BI8B
14
07-21-2003 01:00 AM
