NEED HELP WITH DIZZY!
I searched, counldn't find exactly what i needed to know.
I put a 00 si motor into my 95 integra LS and i need to know what dizzy to use so that i can wire it legit. 0bd2 1-plug dizzy does not wire to obd1 2-plug harness in the car. I heard from a friend that i can use a dizzy from an 0bd1 b16 delsol.
will the obd1 b16 delsol dizzy bolt onto the obd2 motor? and work?
the obd1 LS dizzy would not bolt onto the obd2 motor, i suppose it's because one's VTEC and one is non-VTEC. if the delsol dizzy won't work out, then would should i do next? thanks for any of your help in advance
Re: NEED HELP WITH DIZZY! (Paul*DC4)
94 95 b16 del sol vtec distributor will work. 94 95 gsr distributor will work.. i have one for sale as well.. 94 integra gsr.. will fit any b series vtec head.. its obd1
Location: new jersey home of wanna be's posers claimers ricers biters and where everyone fakes the funk
Re: NEED HELP WITH DIZZY! (geebs)
paul we will re wire your dizzy plug into your harness..just get a legit dizzy asap!
Re: NEED HELP WITH DIZZY! (_HANS)
ok, so the only difference is that one dizzy is designed to fit next to a vtec solnoid, the other is designed for no solnoid. there is no obd1-obd2 differences?
and if i use the guts out of a 95LS dizzy, and put it in a dizzy that will bolt on it should work?
the plugs are different from obd1 to obd2a or obd2b..
you might be able to put the LS internals into the 00 SI housing.. ive never done that..
just repin the dizzy. get an obd1 dizzy side plug and repin it. im usig an obd2 dizzy on my obd1 b16 and have no probs. i`ll c if i can find the link to the wiring diagram.
Re: NEED HELP WITH DIZZY! (biggdogg)
paul. i wish i had more time free to come over and look at it...im gonna have time sunday night if your around.
hans i ordered the right adapter and it came friday, i rewired the harness and put the adapter on, car is still not starting, i need 2000 civic si dizzy, new, to be sure that it isn't the dizzy anymore
CrX-To-Tha-Max-v2.0
02-27-2005 07:29 AM
