2nd Opinion
2nd Opinion
my 4dr eg mini swap sometimes has a hard time starting. i turn the key and nothing happens other than a oil,battery, and vtec light turning on. no noise going off or anything. my starter doesnt go off either. At other times it start up just fine or i turn the key and the lights i mention turns on and then suddently it starts. so im thinking it is either bad grounding or the starter, but im not sure. i know for sure it has to be electrical. what do you guys think?
Re: 2nd Opinion (RinTin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RinTin »</TD></TR><TR><TD CLASS="quote"> so im thinking it is either bad grounding or the starter</TD></TR></TABLE>
you can always look at the transmission ground cable to see if it's torn of worn out
the thing you can't see is your starter solenoid.. could be bad.
find a cheap starter or borrow one from a friend and see if that works.
either way i would check the ground cable anyway
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slacks »</TD></TR><TR><TD CLASS="quote">
I found out my tranny ground was not completly connected. i must have forgot to tighten it when i installed my new tranny. it hasnt failed to start on me so far since i tighten the ground so problem is fixed for now
