d16y8 egr????
d16y8 egr????
HELLO everyone ... my d16y8 p28 is thrown cel 12.. After searching i am very confused...the threads say that vtec motors do not have an egr? also there is alot of talk about cleaning the egr.. if i do have one, where is it located, also will cleaning it fix the problem?
Re: d16y8 egr???? (z6hatchboy)
yeah some civics have an egr like i think civics from florida or carolina have an egr and its almost next to the distributor
but cali civic dont have them
an egr will make a car stumbel and turn off at low idel if its bad
but if you have a ecu from a diffrent state like thoes places then it might set a code since the ecu dont see the egr
my y5 has a egr system..cause it runs so lean honda needed something else to control NOx...plus it a diff vtec setup...but regardless....if you have it....it will me a round valve with a plug in connector....about 2 or so inches up towards the firewall from the dizzy....cleaning the plenum may""""" help it...but anyway gl
Re: d16y8 egr???? (LoWeGz)
It's on the intake manifold. To my knowledge, only the late half of the sixth gen D16Y8's had EGR.
Ever think about getting a Haynes manual? Better write-ups / better pics / more reliable information than you'll find on the internet.
Re: d16y8 egr???? (baller status)
yeah i agree it MIGHT help if you clean it up
but question from the guy above
where did you get the 2 vtec soledoids??
i want that
does it make a difrence
i want that
A y8 does'nt have an Exhaust gas recirculator, the HX civic does , there are 2 10mm bolts on top of the valve remove those and clean out wit a wire hanger, and reset your battery that may turn off the light, anyone have a Y8 head for sale?
svtford4x4
12
03-10-2012 01:44 PM
jamescodylee
04-07-2011 06:02 PM
