OBD1 Jdm Gsr Engine color code HELP!! *Please read*
i picked up my Eg and im dropping in a b16 with but my wiring harness got jacked soO i had to use my buddy's obd1 jdm gsr (right hand drive) harness and i'm jumping all the wires.. now my problem is the color code!! i need to know were a hand fool of the clips go.. therefor i need the obd1 engine harness color code! and i've already google searched and i already searched on here =(... please somebody help me out and its a JDM OBD1 GSR ENGINE HARNESS if it matters!! thanx a lot peeps
Hand...fool? Its handful...
If you mean ecu wiring:
http://technet.ff-squad.com/
But, since I doubt you mean that, and are asking for coloring of every wire on the main wiring harness:
No one is going to tell you what every single wire is. If you want to know, buy a Helms manual. End of story.
a1-brown-injector 1
a2-yellow-injector 4
a3-red-injector 2
a4-orange and white or green- vtec solenoid
a5-light blue-injector 3
a6-orange and black-02 sensor
a7-green and yellow- fuel pump
a8- empty
a9-green and white-idle air control
a10-empty
a11-empty
a12-yellow and green-radiator fan relay under hood fuse box
a13-green and orange-check engine light
a14-empty
a15-black and red-ac compressor clutch relay
a16-yellow and white-alternator
a17-green and black-iab solenoid
a18-empty
a19-yellow-not sure
a20-red-purge control solenoid
a21-red and green-icm
a22-red and green-icm
a23-black-ground
a24-black-ground
a25-yellow and black-ground and to main relay
a26-black and red-ground
b1-yellow and black-goes to pin a25
b2-brown and black-ground to shields for cyp and tdc
b3-for automatic-green and blue
b4-for automatic- green and black
b5-blue and red-ac pressure switch
b6-empty
b7-green or pink and black-clutch switch for cx only
b8-brown and red-power steering pressure switch
b9-blue and white-starter signal
b10-yellow and blue-vehicle speed sensor
b11-orange-cyp p
b12-white-cyp m
b13-orange and blue-tdc p
b14-white and blue-tdc m
b15-blue and green-ckp p
b16-blue and yellow-ckp m
d1-white and blue-fuse 32 under the hood backup power
d2-green and white-brake switch
d3-dunno color-knock sensor
d4-brown-service check connector
d5-empty
d6-orange and blue-vtec pressure switch
d7-light blue-data link connector
d8-empty
d9-pink-alternator
d10-green and red-electrical load detector
d11-pink and black-tps
d12-dunno
d13-red and white-ect sensor
d14-white-o2 sensor
d15-red and yellow-intake air temp sensor
d16-dunno color-vref
d17-white-map
d18-pink and green or white and red-upshift indicator
d19-yellow and green-map
d20-yelow and white-tps
d21-green and blue-map ground
d22-green and white-tps ground
a3-red-injector 2
a8- empty
a10-empty
a11-empty
a14-empty
a18-empty
a19-yellow-not sure
a23-black-ground
a24-black-ground
b6-empty
b11-orange-cyp p
b12-white-cyp m
d5-empty
d8-empty
d9-pink-alternator
d12-dunno
d14-white-o2 sensor
d17-white-map
dutchman5
11-11-2005 08:31 PM
