Del sol Master brake Cylinder
I just bought a del sol that's missing the master cylinder.
I noticed while shopping for one online that there are two different kinds?
One for non Vtec non ABS model, and one for Vtec with ABS?
My Del sol is a 94 ans has disk brakes in the rear , not drums.
How do i find out if i need to get the ABS version of the master cylinder?
Do i have ABS?
Does anyone here know if it maters at all?
can i use any Del sol master cylinder that will fit?
Also does anyone know of any reputable brands or should i stick with OEM?
Thanks
Do i have ABS?
Thanks
So you have an si well the only civic that has abs is the ex-s which pretty rare so no you dont have abs i have a 94 del slo si and they do not come with abs...stay oem if you wanna save money but there is not really a point in upgrading it at all
call you local honda dealer they will give you just about every detail
Thanks a lot man. You have been a big help.
I think i will be buying an OEM part off of Ebay then.
I'm amazed at the quick response.
WOW we both live in Austin!
btw, I have had success using a remanufactured Master cylinder from Oreilly with out a problem. I know that some will not agree on going with reman stuff, but so far have never had a problem and they all come with lifetime warranty. If you have 170 dollars to spend, go with OEM Honda new. But for 29.99 you can get a remanufactured one from any parts store with lifetime warranty. Just make sure to bench bleed before installing. ATX!!
SOLvtec
10
10-29-2006 06:39 PM
