idle drops to almost 0 than jumps
i got a h22 in a 92 hatch. i can drive it a bit and then when i stop the idle drops to almost 0 than jumps up to 1k. it vibrates like it wants to die than surges. what's going on?
my sol does this as well, but only after driving at highway speeds and coming to a stop(like exiting the highway)...i alaways assume its just the fuel trim re-adjusting...my car has never actually stalled out from this
what sucks is i go to a red light and my cd starts skippin. plus at night if im at a red light my headlights shake which makes the car seem junky. i need this fixed bad!
if its getting dim and the head unit is turning on/off i would have your alternator checked. other then that idk definitely check the icv though.
bump iacv was cleaned less than 1,000mi ago,before the engine was even installed.Im thinking my prob could possibly be related to the alternator since my lights get brighter if i rev to 3,500rpm and get dim once i come down from that
Try cleaning out your FITV. Not sure if it would cause the problem when the engine's warm, but it's still worth cleaning. It's just as easy to clean out as the IACV and certainly wouldn't hurt to do anyway.
And even though you cleaned the IACV, as wrenchez81 said, it could be sticking.
try another IACV, i cleaned mine, but after a few months it died... i bought a used one on ebay working perfect, 4 months already...
no check engine light, it's a 98 h22, i dont know about the ecu but i was told it is the appropriate for the car engine swap. car runs strong it's just when it stops.
