civic dead, need help.
okay, last night i started my carand took it out of the garage, it's a 94 civic si and parked it outside, this morning i tried starting it, it won't start. it cranks but won't start. i tried recharging battery already and it won't start as well. what could it be??
When you turn the key to acc does your CEL come on for a second or two and turn off (in other words, is the fuel pump priming)?
Also, check for spark. (don't know exactly what you do to do that... never had this problem.)
If it is cranking it is not going to be the battery. I would be checking the igniter and ignition coil. Remember Honda dizzys of the 90s are their Achilles Heels. For info on checking the igniter and coil, see http://www.tegger.com/hondafaq/faq.html#startrun
lolz, okay it work today, it was weird because yesterday it didn't seem like the fuel pump was priming, today it did and it's alive again. werid, i'm gonna change the fuel filter today just because it hasn't been change for a while now.
That indicates the solder joints on the main relay are probably weak. Take the main relay apart and resolder the joints, or buy a new main relay.
i had kinda the same problem on my 96 civic.
i was driving. took off from a stop sign racing some guy then my car died.
it cranked but never turned on.
i tried jumping it but it just cranked louder and kinda faster but nada.
had it towed home, checked the ignition coil and it wasnt working.
i bought a new one and vuala!
car started! and now it starts faster and sounds better when its cranking
civhatch4life
09-12-2012 12:08 PM
JDM Freakk
06-21-2011 05:36 PM
k_vd16
02-05-2011 01:42 PM
gaydm
03-06-2006 08:19 PM
