New to Honda, need ideas for 95 DX coupe
New User
Ok I am a Subie Guy but Figured I would try out something with a honda. I have an old honda passport that sits in my driveway. A guy I work with wants to swap a 95 DX coupe even with me. It is all factory that I can tell. No power steering and the such. Only thing the car is missing is the muffler so it sounds like hell. It has 212,000 Miles on it. I think I want to make it a project car (i.e. not spend more than maybe 5-7 grand on it). If I pull the d series out, what should I put in? I do not plan on boosting it as I just want something peppy and fun but doesnt have to be an all out race car. I was thinking B18c. I also am going to need to have money left for a little suspension and maybe some wheels. I think I want to use hmotorsonline.com. Any help would be much appreciated.
By the way, my passport is a 1998 with 205,000 on it. It is not in the best of shape so I think the trade is def worth it. Thanks again for your help in advance.
yea its worth if your going to make the car into a project car, and the motor you suggested it perfect, or you could go with a B18b, those have decent power without turbo, but GL with the project
GDD GRAMMAR POLICE
B16
Pros
160 hp stock
High RPM power
Fairly inexpensive
Good transmission
DOHC VTEC
Cons
113ft/lbs torque (very little more than a D16z6 stock)
Without knowing what you're looking for you can end up with a high mileage JDM model
Under 4k or so it feels just like a D16
B18B
Pros
Good torque for a 1.8L (127 ft/lbs)
Inexpensive (even cheaper than a B16)
142 hp (more than any stock D series)
Boost heads love them
Cons
No VTEC
Longest B series transmission
B18C1 (or JDM B18C)
Pros
Good Hp and TQ numbers (170, 121 ft/lbs respectively)
DOHC VTEC
Tons of potential
High revving
Cons
Expensive
Becoming moreso as people keep scooping them up
Slighty longer tranny than the ITR and B16
B18C5 (or JDM B18C)
Pros
GREAT HP and TQ numbers (195 and 134 ft/lbs)
High revving
Hand built motor from Honda
Optional factory LSD
Best transmission for a B series from the factory
Red valve cover
Cons
EXPENSIVE
If JDM ITR is used, the 36mm axle 32mm hub problems occur
B16B
Pros
185 hp 117 ft/lbs
High revving
Good top end power
Red valve cover
Cons
Expensive- almost as much as an ITR for lower performance
Very little torque still, have to rev the motor to make power
B20
Pros
Great torque (133 ft/lbs)
good boost motors
inexpensive
B20z=146hp
Cons
Thin cylinder walls
Have to peice together a swap for a Civic (can't drop it in with a B20 tranny)
Won't pass BAR (light truck motor in a car)
Low hp in the B20b(126 hp)
Pick whichever you think suites you best.
Pros
160 hp stock
High RPM power
Fairly inexpensive
Good transmission
DOHC VTEC
Cons
B18B
Pros
Cons
No VTEC
B18C1 (or JDM B18C)
Pros
DOHC VTEC
Tons of potential
High revving
Cons
Expensive
B18C5 (or JDM B18C)
Pros
High revving
Red valve cover
Cons
EXPENSIVE
B16B
Pros
185 hp 117 ft/lbs
High revving
Good top end power
Red valve cover
Cons
B20
Pros
good boost motors
inexpensive
B20z=146hp
Cons
Thin cylinder walls
