surging prob. PLEASE help
my car keeps reving from like 1000 to 2400 rpms when it running the only way it quits is when your on the gas was is this please help and how to fix it?
Adjust the FITV (Fast idle thermo valve), which is on the back underside of the throttle body. Take of the intake and just inside is a little 1/2inch hole that leads to the FITV.
Take off the the IACV (idle air control valve) Which is on the back of the throttle body it has two coolant hoses connected to it, take it off and clean it with carb cleaner.
Also when your car is on disconnect the TPS and map sensor and see if that changes the idle or slows it any.
what engine you got????
There is nothing to clean in the FITV. The retainer gets loose and causes your fast idle surge. Tighten it a turn or two and your idle will clean up on warm up.
https://honda-tech.com/forums/acura-integra-6/%2A%2A%2A-how-%2A%2A%2A-clean-your-fitv-aka-fast-idle-thermo-valve-1564019/
For future reference, look here first: https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/faqs-frequently-asked-tech-questions-1998336/
If when you unbolt the FITV from the throttle body there is coolant coming out of one of the 3 ports, you're FITV is probably screwed.
ok....but my idle cleans up when the cars warm........it's just I don't like it to idle crazy while warming up........and what do i tighten a turn or two????.....
EDIT: I guess this whole time i've been replying to someone who jacked this thread. lol. You must be talking about the OP. My posts are in reply to "EJ1 LS guy."
I Like Hondas
06-11-2006 05:35 PM
rcjustin
26
02-03-2006 10:37 AM
