00 SI o2 sensor problem
I have a 2000 civic si with a greddy header. I'm using the 2nd o2 sensor for the header but the check engine light is on. Its running really rich right now. The 1st o2 sensor is disconnected. I heard something about using a spark plug non fouler... would a spark plug non fouler fix the problem?
as long as u were here in winter dont come in summer u'll hate it. You can search for p0420 code on here and some1 has prob talked about other ways to make it go away. I think the ECU also looks for temp reading on the 2ndary so it still has to be plugged in but O2 sim isnt that expensive as long as you have both hooked up and plugged in the correct ports. This is where i got mine from so u might wanna check it out. http://www.o2simulator.com/
