Ls vtec wireing
Ls vtec wireing
I was wondering what harness i should use for my ls vtec swap in my 95 dx.
It is an obd0 block.
Also what prelude injectors should i use, or should i.
Thanks.
Thanks.
Use your stock 95 dx wiring harness & adapt it to work with your ls/vtec motor. You may also use an obd1 integra ls or gsr engine harness.
Concerning injectors. Stock 240cc injectors will be fine up to around 195 whp.
Concerning an ecu, I would recommend a chipped obd1 vtec ecu such as a p28 etc.
you need to add wiring for the vtec solenoid and vtec oil pressure switch. you can either run the wiring yourself from the ECU plug to the shock tower plug or you can order a subharness, pre-assembled, from a company such as rywire.
if you're using an OBDI vtec engine harness, the wiring will already be intact up to the engine side of the shock tower plug. it will be a lot cleaner (and a lot more OEM appearing) to run your wiring from the ECU to the unused vtec slots on the car-side of the shock tower plug.
AngelTeg
08-24-2003 07:03 PM
