EG Spedo wont work Already changed Spedo and VSS
Help I dont know what else to do. I have a 95 DX stock that i use for commuting. The Speedo will not work anymore. I tried changing out the Cluster and both top and bottom end of the VSS but it still wont work. Is there a rely or fuse somewhere that i am missing??? I checked but didnt find any fuses for the speedo. Any help would be appreciated. Thanks!
If CEL is on, check the CEL FIRST!!
If the CEL pertains to the speedo sensor, ding ding ding, it's probably just the sensor located ontop of the transmission.
If CEL is NOT on....
Problem: The speedo doesn't work but the odometer works.
Solution: Replace the cluster or just replace the speedo gauge
Problem: The speedo doesn't work AND the odometer doesn't work.
Solution 1*: Bad Sensor - Replace the speedo sensor in the transmission.
*CEL should be on
Solution 2: Bad Gauge - Replace cluster or just replace the speedo gauge
IF Neither solution above fixed it.
Solution 3: Check all wiring from the sensor to the gauge. Because the signal is disrupted somewhere.
*CEL should be on
I had the same problem on my em1. The wire connection on the plug is probably bad. I had to cut one off a junk car and replace it. After that it worked perfect.
hondaboi7
03-18-2009 09:06 PM
hmoobthojboi07
12-19-2008 07:00 AM
