Exhaust Manifold Gasket and Copper Spray
Boy howdy! I am replacing the exaust manifold gasket and I was wondering if it is recommended to use "Copper Spray" on the new gasket (similar to head gasket).
Vehicle is a 1997 Civic CX 1.6 no VTac.
Gracias.
Gracias.
Not necessary, but not going to hurt either I suppose.
I've never used it except for the head gasket. Never used spray, but always have used the brush-on copper sealer. The only thing on the exhaust I've used sealant on has been the turbo to downpipe, in which case I used hi-temp gasket sealer as there was no gasket, not copper sealer.
So... pretty much depends on what you want to do. lol
i've used it on the intake manifold -- you're not going to hurt anything using it and it would suck to put it all back together only to have a vacuum leak. there's really no downside to using it with the exception of having to scrape the old gasket off next time you take it all apart.
Re: Exhaust Manifold Gasket and Copper Spray
would a copper gasket work?
Im doing a header install and looking for options, peeling off the gasket if I have a leak or ever change sounds like a pain, also bumping this to not start a new thread.
copper or oem style gasket for header?
krysted9354
12-17-2008 05:45 PM
