95 honda civic ex cluster problems
Old 12-17-2008, 04:30 PM
hmoobthojboi07's Avatar
Icon6 95 honda civic ex cluster problems
what causes the speedometer(mph) not to work? it only happen to me this winter so far. although sometimes it'll jump up and down too. any suggestions what might cause that?
Old 12-17-2008, 04:36 PM
speed69a80's Avatar
Your fuses are blown out or your guage cluster is missed pluged or it just doesn't work.
Old 12-17-2008, 05:27 PM
it do work but i think it can be the fuses. thanks
Old 12-17-2008, 07:46 PM
danomatic93's Avatar
If CEL is on, check the CEL FIRST!!
If the CEL pertains to the speedo sensor, ding ding ding, it's probably just the sensor located ontop of the transmission.
If CEL is NOT on....
Problem: The speedo doesn't work but the odometer works.
Solution: Replace the cluster or just replace the speedo gauge
Problem: The speedo doesn't work AND the odometer doesn't work.
Solution 1*: Bad Sensor - Replace the speedo sensor in the transmission.
*CEL should be on
Solution 2: Bad Gauge - Replace cluster or just replace the speedo gauge
IF Neither solution above fixed it.
Solution 3: Check all wiring from the sensor to the gauge. Because the signal is disrupted somewhere.
Old 12-18-2008, 10:52 AM
thanks. thats what one of my buddy at work says too
Old 12-19-2008, 07:00 AM
speed69a80's Avatar
Hows the speedo runing now.
duneracer69
12-22-2010 04:33 PM
NSXRguy
05-31-2009 08:52 AM
hondaboi7
03-18-2009 09:06 PM
luder916
12-17-2008 07:57 PM
stivic
10-05-2008 05:25 PM
Quick Reply: 95 honda civic ex cluster problems
