heater coolent is in my car!!!! need help asap
i removed my ac and all the hard piping...there are no leaks on the hoses or the radiator...but coolent coming somewhere from under the dash is in my car n it overheats...where is it coming from and how do i block it...i got an ek hatch dx...need help asap...if you had the same problem and solved it...holla at me
had an issue like this on my accord my solution was to loop the heater hose to the block n not the core thats inside the car and it solved it for me, meanin your core is leakn
on the block? okay see i wanted to just block it off period...can i do that? or do i have to re-route it to the block...im workin wit a d15b jap-spec
You will just need to loop it. Coolant normally flows in one and out the other, therefore, looping it still allows this, but keeps it from the heater core.
What are you going to do when driving when its cold outside? You obviously already know how to remove the whole unit, why not replace the heater core?
you dont have to loop it, you can actually just block the ports and maintain a cleaner look then the big a$$ hose wrapping around the engine. If anybody wants to argue then just think about it, honda put a valve on one side of the core to block the flow when heat was not selected so please dont anybody go there.
mengy007
09-14-2007 09:34 AM
CO_CReX
04-29-2007 06:44 PM
