Question about obd on ls swap into eg
Hi im a little confused on the obds on some ls swaps and the plug and play heres how the list of things im confused about correct me if im wrong:
B18A1 obd1 with the harness that came with it or the harness from the d series in my eg will work it'll go and no prob with a hydro trans ofcourse
B18B obd1 with the harness it came with or the d series harness in the eg will work plug in and go no prob
This one i got off a write up that was stickied it was from Dasfinc heres the link https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/dans-massive-obd2-b18b1-into-1992-civic-cx-hatch-write-up-2239971/ i might have read it wrong though but it was and obd2 B18B from a 96 ls and he used the obd2 B18B harness and it plug right into the eg no prob no modifying if i remember correctly
Also i was told obd0 b18a1 was no good so i was told not to try it one more thing i wanna make sure this is right the obd for the harness and motor has to be the same thanks in advance
Seagull Management
This one i got off a write up that was stickied it was from Dasfinc heres the link https://honda-tech.com/forums/showthread.php?t=2239971 i might have read it wrong though but it was and obd2 B18B from a 96 ls and he used the obd2 B18B harness and it plug right into the eg no prob no modifying if i remember correctly
I think you've got it all figured out. Basically any '92 - '93 B18A1 or '94 - '95 B18B1 engine will work fine. And yes you can use a '96 - 01 B18B1 and drop it in with no wiring if you use the integra harness. In the case of the OBD1 engines you can either reuse the stock civic harness and cut a lengthen a couple of connectors to reach their respective sensors on the new engine. Or use an integra harness and not have to modify anything.
oh and when doing the ls swap with an obd2 b18b using the harness that came with the motor it would plug right into the connectors by the shock towers like in the write up Dasfinc did?
Seagull Management
-Original D-series harness -> you will need to cut and lengthen wires for certain connectors such as the IAT sensor.
-'94 - '95 B18B1 harness -> plugs in, no mods neccessary
-'92 - '93 B18A1 harness -> you may end up not having a map sensor plug using this harness. Check and see if the B18A1 uses a firewall mounted MAP sensor, if does and you have anything but a '92 - '93 DX/LX civic you will not have a MAP sensor connector.
You can use any of the following
Seagull Management
Don't bother with a '90 - '91 you will need to get an OBD1 distributor, possibly alternator, I'm not sure if the OBD0 alternator plug is different then the OBD1 version, same goes for the injectors. The '90 - '91 A1s are only 130hp anyway.
Re: Question about obd on ls swap into eg
would the same apply to a desperate man putting an obd0 b16a into a 93 del sol? been searching, not really sure what im going to need. i just need my car to run
Seagull Management
More or less, although its at least somewhat more worthwhile. Have you considered to trying to sell the B16 swap to an EF guy and then put that money towards an OBD1 B16A swap? The big thing is the tranny, if you can get a hydro tranny the electrical stuff can be delt with at least somewhat cost effectively, you can get 1.6L injectors from a D16Z6, which aren't that hard to find, You will need a distributor though, and I'm not sure about the alternator. If your stuck with the cable tranny i'd have to be pretty desperate before i'd go ahead with this swap.
Ok, this is a little off topic for his situation. But I've got a 96 ex (OBD-2) and have been wanting to drop in a b18b. My question is can I use the harness off the b18b and have it still plug in at the shock tower? Or will I have some wiring to do?
Seagull Management
j4s0n1337
19
07-21-2019 06:47 PM
