A/C problem
A/C problem
I'm having trouble with running a A/C on 99 civic lx. I did some quick diagnastic so far this is what i got. When I turn on the A/C, I get a hot air. The frione is in the system. When dialing the tempature between hot and cold there is no difference. A/C fan does not run when i turn on the A/C.
So what could be the problem?
Re: A/C problem
So neither the heat nor A/C work, right?
Heater: Check the cable running from the heater panel to the heater valve located near the heater hose on the firewall. The cable may be disconnected.
A/C: Check whether fuse 56, 47, or 17 is blown.
Re: A/C problem
i notice when dialing the temperture control above fan control doesn't seem to work.. regardless dialing to cold or hot, it keeps blowing hot air @ same temperture. there is absolutely no difference.
Re: A/C problem
Have you check the three fuses?
