Dropping steering column?
I'm gonna be taking my dash out Sat, was wondering if I could drop whole steering column and all without taking steering wheel off?
I don't wanna break the turn signal sticks while taking dash off.
Any tips and tools I need, I think its just bolted to a support huh?
Thanks
Thanks
Re: Dropping steering column?
yea, u dont need to remove the wheel. drop it. its like 4 bolts. pretty much have to, unless u wanna chance breaking the signal and wiper arms...
to remove dash:
take out the hazard, has 1 screw behind, 2 screws on top of cluster, pop off panel. remove cluster. pop out buttons and unplug. bolt on each side of dash, 1 in top vent, pry from the left. remove console and unbolt 1 bolt in the brackets. and 1 bolt on each side lower down, like inside it...
tools: like 10mm and 12mm
to remove dash:
you can check my whole interior thread....tells you piece by piece what to do....
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/how-diy-custom-interior-project-%2A%2Ano56k%2A%2A-2500737/
Cool beans....i got the jist of dash, was just wanting to figure out the steering column so i can still steer it after i get dash out.
Thanks for the help.
if u look along the cloumn you will see a bracket held on by 2 bolts, remove. then look into the 'holes' under the wheel u will see 2 bolts, remove those also; then it should drop...
