Ebay fogs lights not turning on in 97 hatch
Well ive had these fog lights for awhile and both fog lights took water in them and they wouldnt turn on but the bulbs didnt break. Theres a relay on the harness and a fuse part on the fuse it looks like theres condensation inside the actual fuse i believe its a 10 amp big fuse am i running the right fuse? Also there was corosion on the prongs inside the relay. THere was also so much corrision on the actual power wire inside one of the connectors for the fog light it rusted and broke off.
So I put on a new connector and nothing. Im getting power to the switch cause it lights up when i push it. I believe both lights wont go on if one bulb is dead im not to sure can anyone clarify this also? Anyone know whats wrong?
Re: Ebay fogs lights not turning on in 97 hatch
So you replaced your fuse?
Your wires mightve burned out with the water damage.
Are your grounds connected correctly?
