94 d15b7 extreme oil burning HELP!
94 d15b7 95k miles, 120 pounds compression across all 4 cylinders, PCV clean and making vacuum. When the oil cap is off it literally sprays oil, and running it smokes like crazy. Burns a quart in 100 miles. Runs like a top, still gets 43 mpg. Any ideas?? Is the engine shot?? PLEASE HELP. Thanks!
Re: 94 d15b7 extreme oil burning HELP!
Smoke is blue and definitely oil, it's burning a quart in 100 miles. PCV valve is new and making vacuum at the PCV, valve cover is clean inside and not restricted. Is there any other crankcase vent on this engine besides the PCV?
blue means piston rings are out ,white means the car has been dead or never been running for a while white is actually moisture
i had the same problem in my brother gsr and then he did a full internal replacement( rings,bearings, etc..) after that it stops draining oil
What throws me on this is how good the thing runs, and the mpg, it just doesn't act like rings in my mind....I've not wet tested the cylinders, but compression is consistent even warm.
Seagull Management
I put a headgasket in my first D15B7 (was burning miniscule amounts of coolant but never smoked, car ran fine) as soon as I started it, it was burning oil, a lot of oil. It would take around 3L of oil in under 100kms, you couldn't even see the car for the smoke, but it ran fine. Ran it like that for 4 days and pulled the engine and replaced it with another D15B7, pulled the head on the first engine and didn't see anything wrong, never did pull the bottom end apart.
Resident Gearhead
A compression or leakdown test WILL NOT tell you if the oil rings are worn out. Their sole duty is to scrape excess oil from the cylinder wall to keep as much oil out of the combustion chamber as possible. Oil rings have NOTHING to do with compression.
SimplyTron
07-27-2007 06:50 PM
