Faster power windows?
Got my power everything conversion done in my hatch.
But the passenger window goes up slow until it gets halfway up and then it speeds up.
Any ideas to get it to go up quicker. I already WD-40ed the **** out of the window tracks.
Re: Faster power windows?
try putting silicon lubricant instead on the rubber tracks, i heard that wd-40 is not good for it. if that doesnt help you remove the door panel then put some grease on the metal tracks.
I have a 98 dx hatch and I have been wanting to do the conversion to all power as well, I know the easiest way is to buy ex doors but how do you go about wiring them up the right way?
I can send you a walkthrough if you need it.
Then I went to another junkyard and found an ex floor harness, the whole entire thing is plug and play, except you will have a few extra plugs because the ex had more options {fuel pressure sensor i think, moonroof etc.
Dont forget to get a power mirror switch, 3 20 amp fuses and a power window and lock relay. its pretty easy. the hard part is taking apart the entire interior.
I would take the carpet out too, it makes it alot easier.
Keeep on hand some electrical tape, soldering gun, zip ties and some wire cutters.
My ex harness had the seatbelt plug cut off, so i simply cut the one off my dx harness soldered it to my ex harness.
IF you need any help or anything Pm me.
WD-40 is not good for that at ALL. That stuff eats rubber and metal over time. Google the long term effects of it on bolts and things
onekoop
13
12-19-2005 03:10 PM
00_whytehatch
06-01-2005 10:06 PM
