Getting crank pulley off
Old 07-18-2009, 11:03 AM
mrspeedy69's Avatar
Default Getting crank pulley off
I'm trying to change my timing belt and I can't get the crank pully off. Does anybody have any tips on taking it off. I've tried putting it in gear, putting the spare tire on and setting it on the ground. Also, I tried sticking a big screw driver on the flywheel and still can't seem to get it off. Is there a tool you can rent to hold the flywheel or anything?
Old 07-18-2009, 11:11 AM
john666's Avatar
Default Re: Getting crank pulley off
google crank pulley tool.. i forgot where you can buy it at. i believe some places rent it out also
Old 07-18-2009, 11:20 AM
H-T White Ops
Frozen E's Avatar
3/4" breaker bar and a piece of pipe.
Or just find somebody with an air compressor.
Most shops would be able to crack it loose for you and just tighten it enough to get you back home so you can take it back off with hand tools.
Old 07-18-2009, 11:53 AM
strategy400's Avatar
You can try something like this if you have the pulley w/ holes around the perimeter. Thats angle iron w/ a hole drilled near one edge, a snugged bolt/nut from the back of the pulley, and a small adequate sized 1/4 drive deep socket through the other hole. I think I had to put a pipe on the breaker bar, but with the jack/block of wood to get square torque it came loose with only a small grunt (WD-40 treatment recommended). Otherwise if its the big hex shaped opening on the pulley buy the special tool from some website (make sure you get the right one).
Be sure to use a torque wrench to put it back on after or suffer a possible ruined crank snout/engine. And don't lose the little key.
Old 07-18-2009, 12:00 PM
90Rexx's Avatar
DISREGUARD THAT POST LOL....
you dont have acess to an impact gun? rent what you need to use it, or go to a local shop, pay them to remove the crank pulley bolt, then put it back on looser than factory spec... then drive back home and take it back off....
Old 07-18-2009, 12:30 PM
Former User's Avatar
If you don't have access to a powerful impact wrench, then you will need this tool.
Old 07-18-2009, 01:04 PM
scrambled_EG's Avatar
impact gun and some pb blaster
Old 07-18-2009, 01:53 PM
mrspeedy69's Avatar
Thanks guys i finally got it. Got some more muscle and it finally came off.
Old 07-18-2009, 03:00 PM
H-T White Ops
Frozen E's Avatar
How did you ever come up with that? Oh yeah...
Xscort
07-25-2008 10:54 PM
kojack_0
12
04-23-2008 06:09 AM
coreyhayman
57
10-05-2006 11:44 PM
djnikko
19
04-24-2005 07:43 PM
xrocket21
06-04-2003 04:35 PM
Quick Reply: Getting crank pulley off
