Headlights go out.
Headlights go out.
A couple nights ago I was driving with my headlights on and all of a sudden, they went out. The dash lights went out to. Kinda like someone turned the headlights off by the switch. And wouldnt just come back on, i had to wait a few minutes.
Obviously this is a shortage, right? How do i find out where its short is it?
Its a 97 honda civic ex.
Re: Headlights go out.
like the other guy said, check the wires for the lights themselves. mine payed with me like this when they melted. i had to pop the hood and wiggle them everytime till i rewired em...
i have the same problem too, my tail lights work, my gauge cluster lights up, and my corner blinker lights turn on when i turn my lights on.
are these the same symptoms of a melted wire harness?
First, this isn't a ground issue. The headlights have separate grounds.
Next, have you tried to jiggle the wires at the bulb, my old civic had wiring issues and I had to smack the wires on one side as a temporary fix.
Next, a question. Do your taillights (not brake lights) come on with the headlights as they should?
^^it could be a ground issue theres ground on the headlight harness that could make the lights flicker on and off if they arent bolted down tightly..it could be loose wires... its most likely not a fuse if they came right back on after a couple of minutes
gingerheadman
Honda Civic (2001 - 2005)
06-20-2012 04:56 PM
drumminforev
08-09-2006 07:34 PM
