d15b bogging out!!!!!!!!!please help
i just got done swapping a 1995 civic hatchback cx with d15b vtec and its bogging out before it was throwing a cel for tp sensor and map sensor and vtec solenoid but i replaced the tp sensor now its throwing a map sensor and the vtec solenoid im not to much worried about the vtec yet but could it be bogging out and running funny because of the map and tps sensor or the ecu, oh and btw i had the ecu changed to p28 and i have a sub harness for the vtec so please help me
thanks
thanks
Re: d15b bogging out!!!!!!!!!please help
You no longer have the TPS code, right?
Was the original MAP sensor located on the firewall? Does the new engine instead have the MAP sensor on the throttle body? If so, make sure the MAP sensor connector is plugged into the MAP sensor on the throttle body. Also make sure that none of the sensor connectors were accidentally swapped.
I also have the D15b, but I have an extra plug, and cannot figure out where it's supposed to go. There are three identical plugs, just with different colored wires.
One goes to the Fast Idle Control, one to the MAP sensor, and the other is a mystery. Which goes where?
Plug 1: Yellow with red stripe, green with white stripe, white
Plug 2: Yellow with white stripe, green with white stripe, red with blue stripe
Plug 3: Yellow with green stripe, green with blue stripe, pink with white stripe.
HELP!
HELP!
MAP sensor (if Grn/Wht = Grn/Blu)?
TPS
MAP sensor (if Pnk/Wht = Wht)?
TPS
I took some pictures:
Plug 1: Yellow with red stripe, green with white stripe, white(plugged into MAP sensor. Is that correct?)
TPS That's correct; it's in the TPS sensor.
I am lost.
I am lost.
Are they possibly both MAP sensor plugs, one for the original firewall sensor and the other for the new throttle body sensor?
Where do the wires pin to the ECU?
Holy Toledo Batman, I think you may have something. The one with the pink wire is coming off of the firewall, yes...and the first one is coming off of the main harness.... WOW. I'm blown away. Now I just have to fix the idling problem. I thought it was because of the mystery plug. I'll start with the map sensor!
Does that plug matter anymore? Should I use the MAP sensor on the harness or on the firewall?
The firewall connector should remain free and not be connected to the ECU whereas the wire harness connector should be connected to the TB MAP sensor and to the ECU.
ek9_Junkie
03-15-2009 04:40 PM
94 civic all mtr
12-20-2003 08:18 AM
