b16 clutch - help
b16 clutch - help
okay, i have a 94 del sol.. and it's b16..
now when i park the car and start it in the morning again, the clutch kicks in really low.. i don't know what's wrong with it.. but as i start driving it again, then it starts coming back slowly..
can anyone help me out with this..
Re: b16 clutch - help
check your master cylinder + lines for any fluid leaks.
Also check in your car behind the pedal against the firwall for any signs of fluid leak (it often leaks on the inside) you'll be able to see the stained carpet if it's leaking inside.
x2 sounds like you have a leak...or you need to bleed your clutch
david236kEG
23
01-28-2009 03:34 PM
