intermittent high temperature reading on B18C1
i have a 97 civic with a gsr swap. CTR guage cluster. this happened yesterday, the car was fully warmed up and reading normal temp... then all of sudden the temp guage went to 3/4 and stayed, then sharply fell back to 1/2... it did this a few times, and seemed as though i could almost control the temperature guage by the movement of the vehicle, ( sharp decelleration would cause it to go back to normal range).... coolant level is at full and the wiring and sensor physically looks good... anyone else with a similar experience, or maybe some insight?
Re: intermittent high temperature reading on B18C1
it was bled when the engine was swapped, but ill try bleeding it again, will update if probelem happens again after coolant bleed ;-)
the engine isnt overheating... this is an electrical fault somewhere... engine temp doesnt rise and drop this fast...
im leaning more towards thermostat like everyone else here. i believe your t-stat is sticking.
most likely its ur t-stat..it is either staying open or staying closed..i had the same problem where my car would be in normal operating temp. and when i start driving it would creep down as if the engine was cold..changed the t-stat and fixed
litterbox
03-16-2009 06:50 AM
98, b18c1, bleed, civic, coolant, ctr, engine, gsr, high, honda, intermittently, overheats, replacement, temp, temperature, thermostat, tranny
