99 ek/h22 swap help
Old 08-27-2010, 08:36 PM
Default 99 ek/h22 swap help
I recently bought a 99cx with a complete change over h22 swap from hmotors. Stage 2 axles, LSD. It has a walbro 255 and when it's not warmed up, the car dies at stop lights. Is this a fuel pressure regulator issue? Do I need bigger fuel rails? Also, I'm not sure if it's the tranny or the clutch (act 6 puck) but I hear a grinding noise coming out of first gear. Doesn't do it if the clutch is feathered... doesn't want to go into 5th gear very well, synchros maybe? Any help is very much appreciated, as you can tell I'm new to this. Thanks
c_dioxide is offline
Old 08-27-2010, 08:42 PM
Default Re: 99 ek/h22 swap help
What ECU are you running? It may have the completely wrong parameters for the H22, also make sure the 3 wire to 2 wire IACV was done correctly...
HAMOTORSPORTS is offline
Old 08-27-2010, 09:00 PM
I'm pretty sure it's running on the civic ecu. The guy said it's only throwing the cel because it's still obd1. I have no clue. What do you mean by parameters? I'll check the wiring on the iacv. Thanks
Old 08-27-2010, 09:21 PM
If its using your stock civic ECU, then there's your problem. It is not nearly enough fuel, the idle specs are completely different and you will have the CEL also because of the ECU wanting to 'see' the 3 wire IACV. Your best bet would be to use a jumper harness to obd1 and a chipped ecu with an H22 basemap. You will need to fix the IACV issue either way..
Old 08-27-2010, 09:41 PM
Thank you very much.
cmgibby
09-01-2008 08:39 PM
OAD502
09-06-2007 05:12 PM
Excelerate
10-05-2006 06:15 PM
Excelerate
10-02-2006 10:02 PM
EuRoBrO
07-20-2004 09:54 AM
Quick Reply: 99 ek/h22 swap help
  • Ask a Question
Question Title:
Description:
