Bouncy Idle
Bouncy Idle
So... I have a 94 VX and I swapped a Z6 Intake Mani and Throttle body onto the D15 yesterday. Now it idles really wierd. It bounces really fast between about 700-1000 RPM, up and down up and down. So far I have...
-Disconnected the IACV, jumped the ecu harness, and set the idle with the idle screw
-Cleaned the IACV and FITV
-Ran all brand new vacuum hose as per the underhood vacuum diagram
-Bled the coolant like 29 times
-Checked for vacuum leaks (none)
-Cleaned the IAT sensor
-Checked TPS Voltage (i set it to .5v closed and 4.5v WOT)
I have a CEL Code 14 (IACV). Also, when the IACV power connection is connected the throttle body produces a loud hissing sound from the hole inside and infront of the butterfly. If i disconnect the IACV the sound goes away and the car runs somewhat better.
Any Ideas....
Any Ideas....
Re: Bouncy Idle
Any Ideas....
Any Ideas....
Did you make sure to change the gaskets? And make sure everything is tight on there(just dont overtighten anyting).
erichackett
10
07-27-2010 06:43 PM
