b16a cutting out in vtec
i have a jdm b16a with a p30 swapped in a 95 Si for about 2 years now. ive never had one problem with my engine until recently. i also cleaned my engine bay a few months ago so im wondering if that could have led to my engine problems. i only covered up the alternator so it couldnt get wet. however, i didnt blast anything with a power washer, i just lightly sprayed the water over everything with my water hose and a spray nozzle turned all the way down. im not sure if these 2 occurences have anything to do with each other, i just thought i would put this information out there just in case
my car is running fine under vtec. no stalling, no bogging, it runs perfect under 5xxx rpm's. once i get into vtec, it is cutting out and runs like crap. it will not make a smooth pull all the way to 8k rpm's without cutting out in vtec
today i decided to clean the iacv, new oem dist. cap and rotor, new oem fuel filter, new oem ngk spark plugs. i have some ngk plug wires that still look to be in good condition. after all this, it's still running the exact same.
Re: b16a cutting out in vtec
drove my car to work today and it ran excellent. it pulled hard all the way thru vtec up to 8k rpms without cutting out. i dont get it. yesterday it ran like **** and today it ran excellent. i havent done anything else to it other than what i stated in the first post
CanoTech88
21
05-02-2012 04:32 PM
bonylad
10-03-2006 02:33 PM
NateDawgCRX
09-23-2002 09:13 PM
