To have A/C or not?
To have A/C or not?
Whats up gentlemen,
im in a bit of a rut, and i need some advice.
Im doing a b series swap into my 95 civic, now my car stock does not have A/C.. and after driving in this humidity lately ive decided i want to install A/C in my car..
Since im doing a swap i figured i could add this in during the install. Is this a simple process?? & what stuff would be required if i wanted to put A/C in?
This wont be a track car, this will be a DD
i know i will sacrifice some HP with A/C, but is it a great loss in HP?
I might boost this motor in a couple of years, would this be an issue when the time comes?
sorry if this is a noob question boys but i have never done anything like this before so i figured i might as well ask.
i appreciate any input thanks!
Re: To have A/C or not?
I'm in the process of installing A/C in my car right now. I had some issues because I tried to mix and match R134a and R12 parts, which are different. Go to the junk yard, find a 94-95 Civic (has R134a system, 92-93 has R12 system) and get the entire system. You can get a R12 system and retrofit the low and high side connections, but make sure and use Ether compressor oil because there will still be a little bit of the old oil in the system. You'll need to replace the receiver dryer.
MiG-21 superfan
Whats up gentlemen,
you won't lose any power with a/c when you need it; the ECU will disengage the a/c after certain RPM and throttle angle, and the free-spinning pulley doesn't hurt you at that point.
you can boost with a/c, it will just limit your manifold options a bit, but it's very possible and done quite often.
My cousin has a 600hp Integra with AC
go for AC man
My car measured 130 degrees when I got inside about a week ago, even with one of those sunscreens in the front windshield.
There's no way I'm going without an AC
BTW just about every car in this link has AC and is boosted avg. 300 WHP
http://www.lhtperformance.net/docume...urbo_cars.html
go for AC man
ThaCivicAssassin
04-21-2005 06:02 PM
liljohnson
13
08-19-2004 11:47 AM
