h2b build help??
Old 08-29-2010, 08:46 PM
ricky00's Avatar
Default h2b build help??
ok so i finally decided to do a h2b setup...but there are some question i wanna ask first before doing...
1st. would i need a h22 harness, or would the b series be fine
2nd. would the stock b series axle be fine n what L bracket do i need
3rd. what do i have to hit, cut, wield on the frame
so far i have not invested into this setup, but i am going to do it hopefully be done in 3 months from now.. so far i have is a b16 tranny, long block h22a1 with no harness, intake manifold, exhaust manifold, and dizzy.. planning to rebuild this motor from scratch, but a rebuilt kit for 300, buy the plate including mounts for 1400 (have to buy this **** first or else im never gonna do it), and buy what left i need to get this project running on my eg..
this is my first time doing a h swap.. tired of b series.. i wanna go cheap but fast and decided this was the only way to go
ricky00 is offline
Old 08-29-2010, 09:12 PM
Krut's Avatar
Default Re: h2b build help??
1. The b harness will work, will just have to extend a few wires, like the alternator cables since its on the front of the motor vs the back
2. You use stock b series axles with h2b and a b series L bracket
3. If you move the crank pulley 1/2 over, and shave it down to just the alternator part you shouldn't have to bang the frame at all. All the info you need on how to do this is in the h2b FAQs of the hybrid section
Overall its basically just like a b swap, with the exception of grinding the back of the block and modifying the header to angle right
Krut is offline
Old 08-29-2010, 09:56 PM
93egSLEEPER's Avatar
Throw some k series pistons in that bad boy should be on the list as well. instant upgrade from all i have read about and heard of.
93egSLEEPER is offline
Old 08-09-2012, 06:11 PM
Tkay08's Avatar
good shiit
Tkay08 is offline
Old 08-09-2012, 06:23 PM
Hidenplanvew's Avatar
UMMMMMMMM you just bumped a 2 year old thread with nothing to add ....
Hidenplanvew is offline
Old 08-09-2012, 06:42 PM
Former User's Avatar
Old thread closed.
Former User is offline
Krauthammer
04-17-2019 08:59 AM
Kdx
08-11-2018 06:19 PM
OoAoO
11-15-2008 08:44 AM
Phaze2 Mike
05-30-2005 06:40 PM
careawholelot
10-16-2002 10:24 AM
Quick Reply: h2b build help??
