Door lock problem with Compustar alarm system
i just put the keyless 4dr rear door handles on my 00' coupe
everything is hooked up but for some reason when i go to push my alarm unlock button
the locks open halfway and lock so i cant get in my car unless its through the trunk
i have a compustar alarm and its brand new only a week old
so if any has tried this please try to help me out
thank you
thank you
Re: im NEW to honda-tech...NEED HELP
Change your title and people will be more likely to respond.
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/threads-must-summarize-technical-problem-title-list-car-details-first-post-2809571/
Re: Door lock problem with Compustar alarm system
Did you do the install yourself or did a local shop do it?
Do the locks work using the cars unlock/lock button on the inside?
Did you use OEM actuators or some type of aftermarket actuators?
Do the front locks work fine?
