d16 overheat at 40+mph
hey Honda-tech, i just recently finished rebuilding my ek with d16y7 and before i did the rebuild it was overheating and i figured whatever cause i was just going to rebuild anyway. needless to say its still having this issue of heating up when accelerating to holding at 40+ mph. i never let the car completely over heat before the build and now after the fact im still having this issue! what the hell is the problem??? help pleeeezzzzz
Re: d16 overheat at 40+mph
and no thermostat, i had one on for a bit but didnt make s**t of a difference, and i wired my rad fan to a toggle to run whenever i see fit. the only thing i can think is i was going to clean my icav a while back before build and i forgot to drain the coolant first but i dont think air in the lines would cause this particular result.
------REMEMBER TO KEEP AN EYE ON THE GAUGE--------
Then put the cap back on, and go drive it.
Oh yeah.... is the check engine light on? And are there any coolant leaks anywhere?
Also.... Did you pull the head for any reason?
okay I will do all you suggest. yes the check engine light is on btw, the code was reading I beileive high or low voltage to temp sensor, I'm possitive it reading correctly! also I did have the head off, replaced head gasket and a few valves. thanks
Wow.... So your temp gauge is reading incorrect, and the headgasket had been replaced.
Now... change your temperature gauge, or test the operation.
Then... make sure your head is torqued correctly and there is no coolant in the oil, or vise versa. Or any leaks.
DANG!
DANG!
DANG!
my temp gauge is reading fine now, i went through the harness two nights ago and fixed the problem with it so... THE GAUGE IS GOOD!
I did all the torque specs on the head to the proper amount of pounds, 42 to be exact :D
no coolant in oil/no oil in coolant my friend, thanks for your help thus far, i will status update tomorrow after i run its daily commute and see how she does.
And I never said the gauge was bad fyi.
Keep us posted.
yea were all good now, guess it needed the slightest bit more coolant.
i just gotta throw a thermostat in it now so at steady speed it doesnt slowly heat up.
thanks for the help bro, much appreciated! i woulda spent like 500 on an entire new cooling system if you hadn't recommended those few things.
Yeah man... no sweat. That's what H-T used to be all about.
PM me if you ever need anything else
{thumbup}
I HAVE A D16z6 AND SAME EXACT PROBLEM. its got a new thermostat new head gasket it also had the arp head studs and torqed properly. but i think my problem is the head. because it idles good with no over heat but after driving for about an hour or so it starts to over heat. i check radiator and its low.. no leaks at all idk what it could be other then the head. or motor
^ i like how you comment and dont read my full post....
if you read yes my coolant was low i refilled bleed the system and after driving the coolant is low again.... no leaks at all i even pressure tested the coolant system
you might have a warped head, if your driving at moderate speeds and you start to OH you could be losing pressure do to a warped head and the cooland could be slowly but surely burning up in the cylinders.
Woh woh woh.... Didn't I just help you woth your overheating problem? hahahaha. Stop
yes you did dude :D problem solved im not disputing that, ...buutttt.... elitesky seems to have followed same process and no luck, next to having pressure tested things and the test coming back fine and coolant still vanishing i wouldn't exactly disregard that the head could have slight crack or even moderate warpage.? cheers
mdoubleg
11-30-2010 03:09 PM
94greddycivic
03-29-2004 02:55 PM
