Help! Neutral Safety Switch? No Crank
1992 Honda Civic Si
Ok, so the other day, I go to start my car, and there is no cranking at all. No nothing.
I look down at the floorboard and the little pedal stopper was laying there. Ok, no big deal, I get a new one from Honda and put it in.
But now I still can't get it to crank or anything! I am really doubting the likelihood of the Neutral Safety Switch failing at the same time as the pedal stopper, but who knows.
Is there anything I should have to do after putting a new pedal stopper in?
I need my car to be able to start! I can only start it by popping the clutch, and that is very inconvenient.
Thanks Honda-Tech
Thanks Honda-Tech
Re: Help! Neutral Safety Switch? No Crank
If you can roll start it, then i would say it would be the neutral safety switch, you can bypass it to test to see wether or not it is that
you can bypass it by jumpering the harness as someone else said. if it starts you have a bad switch, if not it's something else. you can also test the switch with a DVOM and see if its working or not.
on the clutch petal there should be a sensor or somethin u should be able to take that out and u should b able to start it with out even pushin clutch in.... i know for a Fact there on Egs dunno bout EK.... and i dun even know what kinda car u got lol in school now doin this but yeah hope it helps u....
If you have cruise control, the clutch pedal has two separate switches. The upper one is the safety starter switch and the lower one is the cruise control switch.
95slomocivi
05-14-2010 03:14 PM
wambus
07-14-2006 01:12 PM
