96 civic hatchback no spark
Old 08-29-2010, 04:36 PM
colbus131's Avatar
Default 96 civic hatchback no spark
Has d16a ran fine til one day im driving and it fell flat. No spark, it will crank but will not turn over. Help!
Old 08-29-2010, 04:38 PM
Technical Hero
HondaPartsHero's Avatar
Default Re: 96 civic hatchback no spark
http://techauto.awardspace.com/ignition.html
Old 08-29-2010, 06:09 PM
tales sol's Avatar
fuel pump priming? main relay problem?
Old 08-30-2010, 11:15 AM
colbus131's Avatar
Fuel pump priming put in new fuse box still cranks but wont start
Old 08-30-2010, 11:25 AM
colbus131's Avatar
Oh car also has msd blaster coil pack and distributor cap
Old 08-30-2010, 12:09 PM
colbus131's Avatar
Check engine light stays on what's that mean
Old 09-01-2010, 08:15 AM
colbus131's Avatar
Anyone?
Old 09-01-2010, 10:33 AM
Former User's Avatar
Pull the CEL codes. Click on CEL sticky at the top.
Did you check whether the timing belt snapped?
Does the distributor get battery voltage at the coil and ICM?
Old 09-01-2010, 07:46 PM
colbus131's Avatar
Checked timing belt that's fine cam is rotating at normal speed changed fuse panel and trased all the wires back all look good. Im trying to do all this crap in my backyard with limited tools and resources. Not sure if the distributor is getting power. Changed the ignitor to see if that was it but still nothing
Old 09-01-2010, 07:49 PM
You only need a short piece of wire to pull the codes and an inexpensive test light or multimeter to check voltages.
Old 09-01-2010, 07:51 PM
colbus131's Avatar
Alright ill keep it posted
NWsleeperswaps
11-24-2015 12:31 AM
bart simpson
10-21-2012 08:02 AM
hardline
15
08-15-2010 11:07 AM
civic91sief
12-11-2009 08:33 PM
pellet36
10
06-14-2009 08:29 AM
Quick Reply: 96 civic hatchback no spark
