95 civic hatch cx - how install rear sway bar?
I have a 95 civic hatch cx with no sway bar in the rear if i buy one will i have to drill holes for it?
Re: 95 civic hatch cx - how install rear sway bar?
Your lca's will work other then having the wrong geometry, meaning you will need to use aftermarket endinks. Like the blox adjustables.
You can use all factory hardware from an integra. The only thing I think that is different is where the bracket actually goes onto the subframe.
what kind of sway bar are you planning to use?
either way, you will need endlinks to connect the swaybar to the rear LCA's pictured here:
unless you end up getting the suspension techniques rear swaybar that mounts to the bottom of the shock with L brackets.
You do not need to drill holes, but if you plan on running a larger sway bar (ie. 21mm +), it is recommended to have some sort of subframe brace, such as ASR.
yea i was planning on a integra one or a 17mm i dont think ill go higher than that but thanks for all the help and i would connect those end links to on of the holes in my LCA's i take it
