3rd Gear Grinds at High RPM on Z6 Tranny
Hey all, I have a 1995 Civic EX with 117k original miles (d16z6) and recently I have begun to experience a grind when I shift into 3rd gear (and only 3rd) at over 4200rpm or so. At first, I thought maybe I missed my clutch point and that is why it was grinding. I might have thought this several times (I don't often miss and I don't drive that high rpm all the time) before I actually realized it was the car and not operator error. My thought is that I damaged the synchro by dropping the clutch too soon at high RPM. What do you guys think, and how much could this set me back to get repaired?
Thanks
Thanks
Seagull Management
Re: 3rd Gear Grinds at High RPM on Z6 Tranny
Depends on whats worn, if its just the syncro ring and you do the work yourself its not going to be too bad, if the gear and/or sleeve is worn its going to cost money.
I'm pretty sure that the gear itself is fine. If I shift under 4200 there isn't any grind at all, and there isn't any sort of vibration. Well, there is ALWAYS vibration in a Civic . The gear doesn't grind if I let the clutch in and out at high RPM either, just when I shift to it.
Only problem is, I've never opened a tranny box in my life. I have an aptitude toward that sort of thing, but I don't know how if I'm honest with myself.
EDIT: What do you guys think could be causing this grind?
That isn't too terrible... Lower than I thought actually. In the case that I end up getting a new one, should I just stick with the Z6 tranny?
i had the same issue with my tranny in my ex, i changed the fluid because it was starting to but the hell out of me, i filled it up with the GM synchromesh, and like magic, all grinds were gone and it shifted so smooth. It is a bit pricey per quart, but it sure as hell beats buying a new tranny and spending the hours putting it in. just my .02
Hey just look on CL im in the northwest area too I look daily for parts there is always something but price's range a bit. If it doesnt grind that much and its a daily I would just leave it cause it's not worth the time and effort I think for a daily.
I had the same problems on my GSR tranny. Got rid of the off the shelf autozone, napa, etc. crap that everyone said would be ok to use, since we don't have a Honda dealer within 100 miles, and filled her up with genuine honda MTF.
Guess what 3rd gear grind is gone and shifts are consistent and smooth now. Won't ever use anything different ever again.
I rebuilt mine. Like you, I had never taken a transmission apart before. Once I got the huge snap ring out and was able to separate the case, it was pretty simple. Just pay attention to the order you take things apart in and have clean space to lay the parts out.
I took pics and made a DIY of the process:
How to Rebuild your Civic's Countershaft
How to Rebuild your Civic's Mainshaft
another route you can go is if you street/strip your car at all or even drive it hard you can invest in some carbon syncros and have your tranny rebuilt and save some bills there and have an overall stronger tranny.
here is the link, the brand i have had the best luck with: http://shop.synchrotech-transmission...ynchros_c2.htm
i wish you luck though, post results if you decide to try something!
this has happened to me numerous times, and has been the shift fork everytime, the shift forks in z6 trans are aluminum and break very easily.....y8 trans do not have the aluminum shift forks, and hold up a lil better in my opinion
is3oo
06-06-2002 10:10 PM
