Idle jumps to 2500 rpms after start up
after shes been sitting for a long time and i go to start her up...the idle jumps up to 2500 rpms....how do i adjust this....
Re: Idle jumps to 2500 rpms after start up
Creating the best thread title helps you get more responses by letting members know what specific information is needed:
https://honda-tech.com/forums/showpo...12&postcount=1
Thread title edited.
If you hope to get useful replies, then provide all relevant information about your car and engine:
https://honda-tech.com/forums/showpo...48&postcount=2
Please familiarize yourself with the stickies at the top.
after your car sits for awhile your battery is going to drain and when you start it you alt. is going to make your engine idle speed higher till it charges the battery back to normal than drop down to 6-800 rpm if this isn't your case you can adjust the throttle cable and back it off.... or mess with the idle adjustment screw on your tb....
be professional
A fast idle on cold start-up is normal. As long as the engine slowly returns to a normal idle as the coolant warms up to operating temperature, there isn't really a problem. That's the way it's designed to work.
Does your engine idle at 700-750 RPM once warm?
yea its a cold start i guess....when i first start it the idle is at 2500rpms...ive never had a car idle that high....is it adjustable?
Its the fast idle thermo valve (FITV). Just took it out on my car and cleaned it. Dont know what car you have but on my 95 civic dx its right under the throttle body. Its totally adjustable, look it up, dont feel like explaining lol.
15 minute job, nothings wrong though.
This thing:
This thing:
yea i have 1....92 dx with a gsr...i cleaned it like 2 months ago...maybe i didnt turn the screw thing inside down far enough.....
As was stated in post #2, you must include this basic type of information about your car and engine in the First Post or Title of a tech thread. A failure to do so will lead to closure or deletion of your threads.
Again, please familiarize yourself with the stickies at the top.
Although this sounds normal....if you have a FITV...it's definitely not a bad idea to clean it...
Look at "Helpful Links" in RonJ@HT's signature box....^ there's a good write-up on how to clean it....
spock_rocker
10-17-2007 08:11 AM
