Whinning from the clutch?
New User
So I take off and shift from first to second, when I push the clutch in to change gears, the car makes a whine noise that fades out with the rpms. Anyone know what could be causing this?
Re: Whinning from the clutch? (dubsee)
if the whine is there at at idle with your foot off the clutch pedal and then goes away when the pedal is pressed in slightly it ususally means that your throw out bearing is going or you could have a leaking clutch master cylinder. HTH
Re: Whinning from the clutch? (94cxhybrid-T)
and if you dont hear a whining at idle, and push in the clutch and hear a whining it could be your throwout bearing.
[Modified by 8grandEG, 8:45 PM 3/26/2003]
________
Mercedes-Benz M120 Engine History
________
New User
Re: Whinning from the clutch? (8grandEG)
Yeah the car sounds different at idle and then when I push the clutch in it makes the whinning noise, its sort of faint, it sounds almost like two things are rubbing together to make the noise. Do you think thats what the problem is?
Re: Whinning from the clutch? (xXTypeONegativXx)
no no guys, it's not the throwout bearing, it's the release bearing... don't get confused here
[Modified by 8grandEG, 9:05 AM 3/28/2003]
________
Honda Zest
Mine makes the same kind of noise in all gears and goes away when the clutch is in. That means my clutch res. and master cylander are leaking or my throw-out bearing is going out. I thought it was my clutch at first but I hook well in second. It can’t be a bad clutch if I can chirp second.
Re: Whinning from the clutch? (Silver Civic OH)
Mine makes the same kind of noise in all gears and goes away when the clutch is in. That means my clutch res. and master cylander are leaking or my throw-out bearing is going out. I thought it was my clutch at first but I hook well in second. It can?t be a bad clutch if I can chirp second.
________
VAPORIZER BENEFITS
revvin9k
04-04-2005 03:34 AM
Full Race A6
09-07-2004 02:12 PM
