5 lug help
Re: 5 lug help (SW20 MR2)
It's hard to get a decent search query going, since archive searching has been disabled. Maybe you guys could answer his question.
Re: 5 lug help (dom93hatch)
If you have a D-Series engine, get a 5 the conversion from a CTR or a USDM ITR. If you have a B-Series engine, you can get the conversion from a CTR, USDM ITR, or a JDM ITR (if you swap out the axles). The JDM ITR has 36 mm axles while the CTR and the USDM ITR have 32 mm axles. If you have a B-Series engine and will be getting a JDM ITR conversion, be sure the conversion includes axles. There are no 36 mm axles available for the D-Series.
You will need the following parts:
- CTR/ITR front and rear brakes
- CTR/ITR front knuckles and hubs
- CTR/ITR rear trailing arms
- 99-00 Civic Si brake lines (ITR & 94-01 Integra lines may also work)
- 99-00 Civic Si parking brake cables (ITR & 94-01 Integra lines may also work)
- 5 lug wheels
The following parts are strongly recommended:
- ITR, 94-01 Integra, or 99-00 Civic Si master cylinder
- 99-00 Civic Si proportioning valve
- 5 lug wheels
Re: 5 lug help (Silverstone00Si)
Front Knuckles/rotors/brakes/hubs/upright arm and A-arm.
Rear trailing arm/rotors/brakes/hubs. If the car does not have rear disc already you will need an Integra e-brake cable (some others work).
Find a seller that will give you everything you need.
Si_Guy2000
Suspension & Brakes
12
01-07-2006 12:24 PM
Uneekpinoysk8er
12-25-2004 08:27 PM
