Why is the J-spec H22A less expensive than most of the b-series motors?
Well, My Si is becoming too costly. I was thinking of selling it for $15,000 (if lucky) with 16000miles. I got it used for $12,500 with 13500miles . So I might save some $ by getting an older HB and swaping a motor in. Here is the site that brings up my question...
http://www.swapjdm.com/swapjdm/honda7.htm
So this is where my question comes into play. Why is the H22A j-spec motor cheaper than most of the b-series j-spec (on that site), even cheaper than the B16A2 (j-spec), when it puts out alot more power?!?
Is it b/c the b-series are more reliable, or that these packages are j-spec, or could it be just as simple as that maybe the H22A they sell has alot more mileage? Sorry if this has been covered, i did search.
Re: Why is the J-spec H22A less expensive than most of the b-series motors? (MikeBSI)
because there is more demand for b series swaps. People are scared that h22's weigh to much.
[Modified by gambit33, 5:08 AM 3/27/2003]
Re: Why is the J-spec H22A less expensive than most of the b-series motors? (gambit33)
but that is just my opinion, but now that i think about it, B series are more popular.
[Modified by HybridHackBatch, 5:10 AM 3/27/2003]
becuase there isn't that big of a demand on them. Its all about demand you can get a beat up sir for like a grand over in japan but the demand is so big here might as well jump the price up and make a profit. Also how are you going to sell a car for more than you bought it.
Re: Why is the J-spec H22A less expensive than most of the b-series motors? (tonesdef)
Thanks for info. I forgot about supply and demand.
Could i sell it for more? O i dunno thats why i put (if lucky). But I got it for a great price with low mileage. But yea, it was not in the greatest condition, it had been sitting out for a while and had some dings but nothing big. No engine problems... yet. I might have it dyno'd this weekend.
Supply and demand, as well as ease of installation. B series is direct bolt in into most cars. H series needs a mount kit and custom axles no matter what car you put it into (not prelude/accord of course). H series also needs custom wiring due to the resistor pack and a few other things. Don't forget the cutting up inside of the car for the shifter plate also.
Re: Why is the J-spec H22A less expensive than most of the b-series motors? (GZR4DR)
Edit: And oh yeah B series are high priced cause they are more in demand.
you can buy a 2JZ-GTE motor with twin turbo for the same price as a ITR motor. (Which i could put a 2JZ in my EH2)
[Modified by ace1875, 10:39 PM 3/26/2003]
Re: Why is the J-spec H22A less expensive than most of the b-series motors? (ace1875)
For Which car are you talkin about I have EH2 and had a H22 in it I didn't have cut nothing for shifter plate things.
Re: Why is the J-spec H22A less expensive than most of the b-series motors? (HybridHackBatch)
not really.... you need more parts to install that motor. b series drop in and the H series usually requires mount kit different axles and random other ****.
Re: Why is the J-spec H22A less expensive than most of the b-series motors? (98Hatch00)
I've installed H22A's into 92-95 civics, 96-00 civics, and 94+ integras. The 92-95 required cutting of the passenger side mount bracket, and cutting of the inside for the shifter to sit low enough not to bottom out. The 94+ teg is identical in installation. The 96+ civic requires no cutting in the engine bay, however it still requires cutting of the shifter area.
If you don't cut i have no idea how you ran your cables for the linkage.
Unceasing Measure
Former Moderator
Re: Why is the J-spec H22A less expensive than most of the b-series motors? (B18C5-EH2)
Place Racing shifter cable box adapter maybe?
