how to replace clutch pedal bracket?
ive dont post here much, but since this forum seems to get more traffic... i thought you guys would be able to help me.
I searched for this problem, but apparently not too many have it.
A few days ago, i was driving normally.. Clutch pedal pressure is hard as usual (heavy duty clutch) all the sudden, BAM the clutch pedal rushes to the floor with no resistance..
I checked and replace the clutch cable.. not the problem.
I look under the dash and i find that one of the welds broke on the Clutch bracket. Damnit..
So my question for you guys, what should i do?
Ive been told its a hard job to do, and time isnt on my side..
The pedal is tweaked to the side, and the clutch bracket needs to be replaced. how do i do this? do i need to replace the whole pedal assembly? thanks
_______
_______
Re: how to replace clutch pedal bracket? ([626]Rj-SiHatchy)
just replace the braket, u can reassamble it and keep everything from your old pedal assembly. So just get the bracket
If you won'T find the bracket, ask me
Re: how to replace clutch pedal bracket? (AcuraEL)
I bought the whole pedal assembly from a local parts store... I started working on it earlier today.. So far ive dropped the steering column, and i loosened most of the bolts.. This is harder than i thought it would be.. what a pain in the ***. it seems as if some bolts are impossible to get to..
anyone have any more insight on this? thanks
JDM_rolex
06-11-2007 07:58 PM
