how much brake fluid for a rear brake swap
most likely gonna swap out the rear drum for discs and change the front pads this weekend. how much fluid should I have on hand? TIA
Re: how much brake fluid for a rear brake swap (slomofo)
Buy three or four small bottles or just two of the big ones. You gotta bleed the crap out of them.
Re: how much brake fluid for a rear brake swap (Civic242)
Try to plug the brake line with something, don't pinch it, so your not draining the entire line back to the M/C.
Nah you'll just need one large one but I'd buy a second if you have problems. Try to plug the brake line with something, don't pinch it, so your not draining the entire line back to the M/C.
I don't think I even used an entire small bottle when I did mine.
Re: how much brake fluid for a rear brake swap (enrique)
good luck
hermtm2
05-08-2009 10:33 AM
PINKS
10-18-2007 04:25 PM
PINKS
10-18-2007 06:04 AM
dutchman5
03-25-2003 03:26 AM
