my motor is running lean
senior gold member
Re: my motor is running lean (2camsaam)
I would imagine that its either bogging out like in my case or hes hearing slight detonation. I raised my fuel pressure and it no longer bogs but it does detonate a little if I gun it.
Re: my motor is running lean (ek4 fa sho)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek4 fa sho »</TD></TR><TR><TD CLASS="quote">i have fpr and it's at 50 psi right now but still running lean. could it be the fuel pump?</TD></TR></TABLE>
How are we suposed to help you if you don't list your set-up?
List your set-up and how you know it's runing lean.
btw bogging is a sigh of a rich condition.
If it's lean it will just drop off in power (won't feel like it's acclerating as fast)
senior gold member
Re: my motor is running lean (b16ahybrid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16ahybrid »</TD></TR><TR><TD CLASS="quote">
If it's lean it will just drop off in power (won't feel like it's acclerating as fast)</TD></TR></TABLE> let me rephrase that. It was hesistating and it all went away after I raised the fuel pressure. But yeah we need to know his setup to help him out.
Re: my motor is running lean (Ivan)
stock compression, stock fuel system and they guy that installed my my head said i needed a fuel pump the 99 si vtec fuel pump. is that the problem?
Re: my motor is running lean (vtecvoodoo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecvoodoo »</TD></TR><TR><TD CLASS="quote">you don`t need jun III`s w/ that setup.</TD></TR></TABLE>my block is in the process getting done
senior gold member
Re: my motor is running lean (B.CRUZ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B.CRUZ »</TD></TR><TR><TD CLASS="quote">vroom vroom. </TD></TR></TABLE>beep beep
on topic. I think its your fuel system.
