ATTN: ALL 99-00 hatches with b20 and A/C... help please.
well guys this is my problem... I am near the end of my motor swap. And the only thing left is the A/C to be installed. I have a b20b block and i have a stock sohc a/c compressor. i was wondering which a/c compressor bracket to use, in order to retain A/C. thanks
Re: ATTN: ALL 99-00 hatches with b20 and A/C... help please. (Chris y0!)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris y0! »</TD></TR><TR><TD CLASS="quote">del slo vtech?</TD></TR></TABLE>
3000+ post and you still put the H
Re: ATTN: ALL 99-00 hatches with b20 and A/C... help please. (O.G triple O.G)
thanks for the help... but i need to be absolutly (spelling) sure.
Re: ATTN: ALL 99-00 hatches with b20 and A/C... help please. (Incubus05)
i have already tried the del sol bracket and it mounts to the block but i am not sure if it is a p54, and only 2 bolts on the compressor mount on the bracket, AND the spindle for the a/c belt do not match up.
PLEASE HELP
TTT
PLEASE HELP
TTT
HELLO,GOOD MORNIN'
Del Sol B16a.....now go to honda and buy it. It's a p54somthin...somthin bracket.
If all else fails go to hasports.com and buy there's for $165
ok I have a b20 in my car... used p54 from del sol si ... go to hparts online... they have it he cheapest... used my stock civic a/c ... it will work .... I have a link of an actual pic of the bracket, but I am at work right now.. I will post it in a little bit... also try the b20 bracket if your motor came with it ... rumor says that will work also, but I have yet to personally see this... good luck! // lata RJ
Re: ATTN: ALL 99-00 hatches with b20 and A/C... help please. (b20guy)
b20 guy is right if your b20 came with the ac bracket it should work. Well it worked in my 97 hatch with factory compressor. The mount was like a p7j or somthing like that.
Re: ATTN: ALL 99-00 hatches with b20 and A/C... help please. (ef ect)
the a/c bracket did not come with the motor.... i bought it at the junkyard.
THANKS FOR EVERYONES INPUT
yh23
08-10-2005 11:16 PM
Fuster_Cluck
10
04-22-2005 10:46 PM
